Starbuck1975
Decided to run 3DMark03 on a system I built 3 months ago, as its gaming performance is not where I expected it would be given the technological component leap over my previous system. When running the FutureMark comparison utility, I am noticing systems that are scoring significantly higher then mine with similar components. Anyone think these scores are a bit low given my components?
Oh, and for some reason, I received an error message when trying to install 3Dmark06...I believe it is a pixel shader error?
General Information
Operating System Microsoft Windows XP
DirectX Version 9.0c
Mobo Manufacturer http://www.abit.com.tw/
Mobo Model AN8 32X(C51-CK804)
AGP Rates (Current/Available) N/A / N/A
CPU AMD Athlon(tm) 64 X2 2021 MHz
FSB 202 MHz
Memory 2046 MB
Display Information
Graphics Chipset NVIDIA GeForce 7900 GT KO
Driver Name NVIDIA GeForce 7900 GT KO
Driver Version 9.1.3.1
Driver Status WHQL - Not FM Approved
Video Memory 256 MB
Core Clock 518 MHz
Memory Clock 747 MHz
Sound Information
Sound Adapter Driver Name SB Audigy 2 Audio [9C00]
Sound Adapter Driver Version 5.12.8.1164
Benchmark Settings
Program Version 3DMark03 Revision 6 Build 0
Resolution 1024x768@32 bit
Texture Filtering Optimal
Pixel Processing / Antialiasing None
Post Processing false
Vertex Shaders Optimal
Main Test Results
3DMark Score 17756 3DMarks
CPU Score 1053 CPUMarks
Detailed Test Results
Game Tests
GT1 - Wings of Fury 358.4 fps
GT2 - Battle of Proxycon 149.3 fps
GT3 - Troll's Lair 120.3 fps
GT4 - Mother Nature 102.2 fps
CPU Tests
CPU Test 1 111.5 fps
CPU Test 2 19.7 fps
Feature Tests
Fill Rate (Single-Texturing) 4966.7 MTexels/s
Fill Rate (Multi-Texturing) 11623.1 MTexels/s
Vertex Shader 50.2 fps
Pixel Shader 2.0 385.4 fps
Ragtroll 76.5 fps
Sound Tests
No sounds 71.5 fps
24 sounds 64.2 fps
60 sounds 58.3 fps
General Information
FSB 202 MHz
Memory 2046 MB
Display Information
Video Memory 256 MB
Core Clock 518 MHz
Sound Information
Benchmark Settings
Main Test Results
Game Tests
CPU Tests
CPU Test 2 19.7 fps
Feature Tests
Ragtroll 76.5 fps
Sound Tests
No sounds 71.5 fps
24 sounds 64.2 fps
60 sounds 58.3 fps
