are there competent car mechanics out there?
dolph
3,981
about a year ago, i was given my car to take up to school. before i drove it up, i had it checked out and oil changed (local dealership - place #1, 27,000 miles). there was a small oil leak, but it would take more time than i had to find it and fix it, so it was determined i could safely drive it up to school and get it fixed there (within 1000 miles). since it was under warranty, i took it to a local dealership once i got back up (place #2, 27,500 miles). it took me going there 3 times before they determined that there was no oil leak anymore. when i drove the car back down south, i took it to the local dealership (place #3) for the 30,000 mile inspection. they claimed to have found the oil leak and fixed it. when it was time to change my oil several months later i brought it to a jiffy-lube type place (place #4, 33,000 miles). the guy who worked there told me that my fluids were filthy, showed me mine and what clean ones looked like, and they should really be flushed. i found my 30,000 checkup description, and it never listed flushing the fluids. i wound up paying 4 times what i was going to for just the oil change, but i figured if my car needed it so be it. a couple months later (tuesday), i brought my car in to a mechanic to have the brake pads replaced (place #5, 34,000 miles). someone asked to borrow my car today and when they returned they told me they smelled burning oil. i checked the dipstick and there was virtually no oil in the car. now i have to go to another mechanic, but frankly i'm really worried that it won't be the last time for the same problem. i don't fault the first dealership i went to for not fixing the problem, i never asked them to and they i didn't give them enough time. the 2nd and the 3rd places were jokes. i'm not sure if the 4th place was scamming me, so i'll give them the benefit of the doubt and assume they weren't. i know i didn't hire the 5th place to fix an oil leak, but maybe they might have noticed the burning smell? or possibly have checked the oil? next week i'm bringing the car back to place #1, because the manager's my uncle and i haven't seen him in a while. but damn... cars can suck.
btw, this was a 1999 toyota camry. which had almost no problems before this oil leak, except that it bottoms out very easily and one of the air vents is loose - both problems i was told were "impossible to fix and i'm just going to have to live with them."
edited to indicate miles at each place. oil had been changed religiously every 3k miles before i got it and since.
Evadman
Administrator Emeritus<br>Elite Member
Feb 18, 2001
30,990
There are a few of us around.
I will read that block in the morning. My eyes hurt now.
<---- going to bed.
ThisIsMatt
Banned
Aug 4, 2000
11,820
wait wait wait...you didn't mention how many miles you put on it between oil changes or how many miles it has now and how many it had when you got it.
dolph
3,981
updated.
ThisIsMatt
Banned
Aug 4, 2000
11,820
updated.
You only explicitly indicate that it was changed at 33,000...so does that mean the previous change was further back than 27,000 miles??? Personally, I think that's quite a bit overdue for a change.
If it's actually burning oil at this point, you're pretty much screwed. Leaking externally is one thing (no big deal as long as you keep the correct amount of oil in), but burning it means you have permanent damage to your engine (well, maybe only permanent until you have an engine rebuild :p).
As for it bottoming out easily...I assume it's not lowered and has the factory springs? You might just need new shock absorbers, or I suppose you could get some tighter springs, but you shouldn't need to. Or, just stop driving like an idiot if that's the reason ;)
I don't think you can fault anyone but yourself if you let the oil go too long before changing and if you let it get low...
dolph
3,981
thisismatt -
sorry for not being clear enough. oil was changed every 3000 miles, period. and i think i would have been the first person in history to purposefully lower a camry.
Bulletins for 1999 Toyota Camry LE Sedan L4-2164cc 2.2L DOHC (5S-FE) MFI
Service Bulletins
TSB Number Issue Date TSB Title EG003R-02 MAR 02 Emissions - OBD II Readiness Monitor Drive Patterns
EG007-02 MAR 02 Valve Cover Oil Baffle - Damage Prevention
SU001-02 MAR 02 Rear Hub Bearing O-Ring - Service Tip
PG008-02 JAN 02 Certification Label - Replacement Availability
PG009-02 JAN 02 VIN Plate - Replacement Availability
ST008-01 DEC 01 Front Suspension - Squeaking Noise
BO030-01 DEC 01 Windshield Wiper Blade - Maintenance and Cleaning
EL010-01 OCT 01 Keyless Entry System - Identification/Programming
BO026-01 OCT 01 Seat Belts - Shoulder Anchor Tape Set
BO025-01 OCT 01 Interior Trim - Sun Visor Vanity Mirror Broken/Damaged
BO020-01 AUG 01 Sliding Roof - Diagnostic Tips
BO017-01 MAY 01 Power Seats - Movement/Adjustment Inoperative
EG005-01 APR 01 EVAP System - Supplemental Operation/Diagnostics
EG004-01 APR 01 MIL ON - DTC P1133 Updated (Oxygen Sensor Circuit)
BO011-01 MAR 01 Seat Belt Tongue Plate Stopper - New Parts
ST001-01 FEB 01 Steering Wheel Nut - Torque Standardization
BO002-01 JAN 01 Seat Belts - Extenders
BO028-00 NOV 00 Trunk - Water Leaks
BR004-00 OCT 00 Brakes - Pad Clicking Noise
EL011-00 OCT 00 Daytime Running Light - Disabling Procedure
AX007-00 SEP 00 Alloy Wheel - Identification and Application
ST004-00 JUN 00 P/S - Power Steering Rack Squeaking Noise
ST002-00 MAY 00 Repair Manual Corrections -Torque for Steering Wheel Nut
SU002-00 MAY 00 Suspension - Rear Axle/Shock/Coil Reminder, ABS
BO009R-00 APR 00 A/C - Loose Center Vent Adjustments
EL007-00 APR 00 A/C - Heater Control Assembly Instructions
AX003-00 MAR 00 Antitheft - Trunk Courtesy Connection Standardized
PG006-00 MAR 00 Emissions - CA/50 State Certified Emission Control Label
NV007-00 MAR 00 Mirrors - Wind Noise from the Door Mirror
BO015-00 MAR 00 Mirrors - Installation of Door Mirrors
AX001-00 MAR 00 Vehicle - Towing Guide.
BO009-99 MAR 00 A/C - Loose Center Vent Adjustment
EL003-00 FEB 00 Instruments - Speedo/Tachometer at Zero First Few Miles
BO002-00 JAN 00 Seat Belts - Extenders Available
SU001-00 JAN 00 Suspension - Front Support Change Reduces Noise
PG032-99 DEC 99 Year 2000 Readiness Disclosure
BO020-99 DEC 99 Seats - Bottom Cover Looseness
BO021-99 DEC 99 Sunroof - Inoperative
BO017-99 NOV 99 Windows - Door Glass Displacement
EL006-99 OCT 99 Antitheft - Engine Immobilizer System Cautions
EG009-99 OCT 99 MIL ON - DTC P1133 Oxygen Sensor Circuit Response
BO012-99 SEP 99 Windows - Door Glass Displaced
BR004-99 JUL 99 Brakes - Updated Drum Reduces Groan/Howling
SS002-99 JUL 99 1999 Special Service Tools
EG004R-99 JUN 99 MIL ON - DTC P0446 EVAP Vent Control Circuit Defect
PA004-99 JUN 99 Paint - Two Tone Color Scheme
TC003-99 MAY 99 A/T - Fluid Interchangeability
AX006-99 APR 99 Antitheft - Changes For GBS Glass Breakage System
EG004-99 APR 99 MIL ON - DTC P0446 EVAP Vent Control Circuit Malfunction
BO007-99 APR 99 Lights - Headlight Alignment Modified
AX005-99 APR 99 Antitheft - Programing the Remote Control
TC002-99 APR 99 Drivetrain - Revised Drive Shaft Grease
SS001-99 APR 99 Antitheft - Scantool Immobilizer Key Code Utility
BO005-99 MAR 99 Interior Trim - Center Console Latch Improvements
AX004-99 MAR 99 Vehicle - Towing Guide
PA002-99 MAR 99 Paint - Refinish Formula Codes
SS003-98 DEC 98 Accessories - Rivet Nut Tool
The four cylinder models have been known plug up the PCV valve (Postive Crankcase Ventilation) which will cause a increase in pressure inside the engine, this can force oil past gaskets and seals.
The best thing to do at this point, clean the engine and over the next week keep an eye on it.
Look closely for oil wetting on around the valve cover, front crankshaft pulley,oil pan,oil filter gasket and distributor.(A common leak on Toyota's)
It is common knowledge that Toyota's with the V6 have sludged up thier internals from the use of poor quality oils, in fact Toyata had to issue several TSB's and sent letters to thousands of owners nationwide.
Do you own a digital camera ?
If so, please PM me.
