My dad wants a battery powered leaf blower for Christmas, but I'm a bit suspicious if battery powered leaf blowers are any good. It doesn't need to be super powerful (he has a battery powered edger that he's happy with). Thoughts?
X2 on that.I personally will only use gasoline backpack leaf blowers, everything else is a waste of time.
battery powered blowers are going to be next to useless except blowing dust out of your computer case lol.
yea id suggest against it as others have said. I have a corded one (was free) and it works on dry leafs that are not too thick and grass clippings, TBH its easier to just rake
The Lithium-Ion EGO is the most powerful leafblower at 56V and can be found at Home Depot. I believe it uses a brushless motor which makes it more powerful and efficient. While at 500CFM it won't equal to even the lowest tier gas blower, it does a very admirable job and is way lighter and quieter.
http://www.homedepot.com/p/EGO-480-...ery-and-Charger-Not-Included-LB4800/205163086
You might want to check out the Black & Decker 36v LiIon blower. I haven't used it, but do own the rotary trimmer from the same tool "family." Battery's pretty light and packs a ton of power. I can easily edge my whole lawn (average suburban lot) a good 3 times before needing a recharge.
It was necro spam with the spam post now deleted.jesus this is a helluva necro and nobody has even noticed?
I have a corded Toro leaf blower and the thing picks up wet and frozen leaves(live in Chicago). It works fantastic. Just make sure you get the one with the metal blade if you are going to suck up the leaves, cause the plastic blade breaks pretty easy. I have been using it for 3 years now without issue. I would suggest getting a decent 16ga cord as well.
As far as the battery blowers, I would stay away from them. They get decent power, but the batteries drain pretty quickly, and they also don't last very well over time. And the batteries aren't cheap.
