are several low-wattage lightbulbs more efficient than one big one?
dpopiz
4,454
if I have say 4 50W lightbulbs, would they combined give off a greater amount of light than a single 200W bulb?
and what about speakers?
if I have 4 speakers each with a 100W amp, do they give me more sound than a single speaker with a 400W amp?
Tom
light output is measured in lumens, not watts.
sound output is measured in decibels, not watts.
There is no way to measure light output or sound output by watts.
Zenmervolt
Elite member
Oct 22, 2000
24,514
44
Wattage is just energy used. It's not a measure of useful output.
A heavy-duty 60 watt bulb may put out as few as 490 lumens, while another 60 watt bulb may put ou 680 lumens.
Likewise, one 100W speaker may only be capable of 90 decibels, while another may be capable of more than 100 decibels.
There are way too many variables here.
ZV
JulesMaximus
74,584
984
There are several low wattage light bulbs and probably a few burnt out ones on this forum...I'm sure a few of them could help answer your question. :D
Schrodinger
1,274
*ahem* someone sounds like they are attempting an MJ grow with fluros... ;) (PS forget fluro and go with the high pressure sodium "son agro" by phillips, its good for both veg and flowering states)
what, why are you guys looking at me? :eek:
0roo0roo
64,795
84
no its a valid question. i think its 60watts that aren't very efficient. just divide out the watts per lumen. something about the 60 not getting quite hot enough.. or something. i'm lazy, just divide it out!
i read this somewhere i cannot remember where..oh wells.
SelArom
872
www.djselarom.com
if light works like sound (seems like it does) then adding more light bulbs in one area of lower wattage WILL increase light, but logarithmically (or something). meaning that you'd have to add a crap load of lights to get just a little brighter
that said, if you spread out a bunch of smaller watt light bulbs around the room, you should get better lighting than one big light in the center.
OffTopic1
1,764
Even light is better than single hotspot. The room will look brighter if you eliminate shadow, and white colour walls/ceiling/funitures will also help.
Luxeon star LED 1 watt = 30 lumens
Shanghai Yaming Compact Fuorescent Lamp Twist 7 watt = 350 lumens
Shanghai Yaming Compact Fuorescent Lamp Twist 23 watt = 1173 lumens
GE compact fluorescent 7 watt twintube = 400 lumens
GE compact fluorescent 13 watt twintube = 800 lumens
T5s/T8s fluorescent tube 1 watt = 60 lumens
Incandescent clear 40 watt = 350 lumens
Incandescent frosted 40 watt = 340 lumens
Metal Halide can get as high as 1 watt = 70 lumens
High pressure sodium can get as high as 1 watt = 85 lumens
High pressurs mercury can get as high as 1 watt = 52 lumens
gabemcg
2,597
Overgrow
Eli
Super Moderator | Elite Member
8
Overgrow
While it's the best of the best, it probably shouldn't be linked to here ......
ribbon13
9,343
I use overgrow on my ginseng. Seriously. I have a killer clone chamer setup that would easily grow Sativa with >18% D9THC, but ginseng is legal, and very profitable.
Besides, there are places all over the world where its legal to grow Marijauna. Alaska for one...
Ready
1,830
I'm not sure, but can i have $5 anyway:?
Eli
8
This guy knows his lights. ;)
Let's add a few more.. Hmm..
40W GE Soft White = 490 lumens
60W GE Standard = 865 lumens
60W GE Soft White = 840 lumens
75W GE Reveal = 830 lumens
75W GE Soft White = 1170 lumens
100W GE Soft White = 1690 lumens
100W GE Extra Soft White = 1585 lumens
100W GE Reveal = 1260 lumens
40W Philips Soft White = 500 lumens
60W Philips Soft White = 860 lumens
75W Philips Soft White = 1180 lumens
100W Philips Soft White = 1620 lumens
135W Philips Frosted = 1760 lumens
150W Philips Frosted = 2850 lumens
200W Philips Soft White = 3675 lumens
300W Philips Frosted = 6300 lumens
100W Philips Duramax = 1675 lumens
150W Philips Duramax Soft White = 2310 lumens
150W Philips Duramax Clear = 2850 lumens
60W Sylvania Soft White = 870 lumens
75W Sylvania Soft White = 1180 lumens
90W Sylvania Energy Saver = 1510 lumens
100W Sylvania Soft White = 1710
yeah, im bored.
Eli
8
Lately, I've been getting no-brand Inside Frost indoor lightbulbs at Home Depot.
60 watts, 890 lumens.. and each pack of 4 is only like 69 cents.
I've actually been meaning to change the few remaining normal bulbs to CF bulbs though...
Hayabusa Rider
Admin Emeritus & Elite Member
Jan 26, 2000
50,879
4,268
Well, I just happen to have an answer to this one :p
All else being equal, a single light is more efficient. Whether is is more suitable for an application is another matter. Those 4 bulbs would give off more even lighting, reducing shadows, but if you wanted more light to read a book, the single bulb is better.
dpopiz
4,454
yeah I can tell...man, for some reason it annoys me when a moron "explains" to my why my question is stupid
0roo0roo
64,795
84
40W GE Soft White = 490 lumens =12.25 lumens per watt
100W GE Soft White = 1690 lumens =16.9 lumens per watt
sharkeeper
10,886
Low pressure sodium (LPS) lamps are approaching 200 lumens/watt. Too bad the CRI is (for all intents and purposes) 0. They are good for security lighting and for lighitng of tunnels that run east and west. (used for sunbound driver vision acclimation zones)
Howard
47,982
11
Bad analogy with speakers. Depending on where they're placed and what frequency they're playing, they could give you absolutely 0 output at certain spots. Besides, few home speakers can handle 400W continuously.
OffTopic1
1,764
I don't know much about lights, However, my photography background and the home renovation taught me alot about lightings.
You need 30 foot candles for reading and 40 fc for high activities. Therefor, I designed my living room with even 35 fcs dimable, and kitchen with 45 fc. I was going to design my own T2s lighting (1/4 inch tube) under cabinet lightings, however the city aholes wouldn't approve my design due to archaic electrical codes.
