Are my voltages way low?
Fullmetal Chocobo
Moderator<br>Distributed Computing
Moderator
May 13, 2003
13,704
7
I'm guessing that the software is messed up, because having the negative voltages at 0 might mess things up to where your machine wouldn't be running. Are you having any strange problems / errors?
PliotronX
8,883
107
My motherboard reports rails that all dip down near uncomfortable levels, especially 3.3, even with different PSU's, but a DMM proves otherwise. For example, mobo says 3.3 fluctuates between 3.05 and 3.24. DMM says 3.32 solid.
Moral: if you're really worried, get a DMM if you don't have one already and check this out.
AFAIK the negative rails aren't really used any more so they are not important. Many PSU's don't even have them these days (might've been removed from the ATX spec).
biostud
19,848
6,941
if your +5V was actually 3.15V I'm pretty sure your computer wouldn't work at all.
Bozo Galora
7,271
one of two things-
you have to pick correct monitoring chip from flyout menu for your mobo
(voltages/voltage config) and you have to lower interval check to lower number from default 10 - to like 2 sec or you will have to wait for change to occur AFTER YOU CLICK ON APPLY.
Edit:
Or, mobo mon stopped updating in Jun '04 and your mobo chip is too new and not supported
memo
1,345
ok cool guys, yeah my computer is running fine at the moment so i was assuming it was some setting in MBM, i just havent gotten around to fiddling with it yet. thanks for the advice.
