Are my 3dmark scores on track?
jhill1
95
this is my old set up, and nothing overclocked:
5658 in 3dmark06 (i cant get the page to work, it only compares it to itself)
after i oc both the cpu and gpu im hoping for around maybe 6k?
so ya i think ur score is low
thilanliyan
11,944
2,171
Originally posted by: coredumperror
I think I figured out the problem. My Radeon x1900xtx seems to be clocking itself at 500mhz core, 594mhz RAM. Isn't it supposed to be 650Mhz core, 775Mhz RAM? I tried clocking it up to those settings with ATI Tray Tools, and the fan suddently went from silent to loud as hell, and then my system froze and my monitors turned off, so I quickly hit the reset button. What the heck is going on here? I've also noticed that during the 3DMark06 tests, the fan never makes any noise, so I'd assume that it's not clocking the speeds up only during active 3d rendering.
When you're at the desktop it clocks down to 2D mode which I think is 500core, 600mem.
Matt2
4,762
DOH!
If you're using ATI TT or ATI Tool, make sure you disable ATI Hotkey Poller through services.msc
GundamSonicZeroX
2,100
Originally posted by: Navid
Originally posted by: GundamSonicZeroX
Try defragging. Even though the installo is new, it can still be fragmented.
Doesn't each test fit completely in the RAM?
Have you ever seen 3DMark access the hard drive during any of the tests?
Defragging works I tells ya.
Matt2
4,762
LOL, I just looked at disk defragmenter - 38% fragmentation.
GUess I'm defragging tonight,
sanitydc
172
when I installed my TV Tuner it auto installed the ati tray tools, how do I get rid of em... I dont see them in program files or add remove?
