Are motherboard traces conductive?
Antoneo
I was just wondering but are the visible traces on motherboards (or any PCBs) conductive? Or is a non-conducting clear coat applied over the entire board?
Originally posted by: Dasterdly
If you install the mb without stand-offs it will most likely short out and not boot.
I did this...
I had an older computer that just wasnt working, so I had the MB tipped up as I plugged it in. I layed it down in the case, and I heard some zapping noises and seen some sparks...
