Are GPUs And Graphics Cards Manufactured In The Same Place?
Gizmo j
1,751
458
I know that there are a bunch of different "graphics cards" brands but only 2 "GPU" brands (Nvidia/AMD).
So I was wondering if Nvidia/AMD Manufactured there own GPUs independently....do they?
Kaido
Feb 14, 2004
51,941
7,408
On the tangent of GPU's, I had a first-world problem today:
1. My computer is from 2013. At least, that's when the final beta BIOS was released. The newest GPU the beta BIOS allows me to run is a 1080 Ti.
2. My 1080 Ti died today. The only card I had available as a spare was an old 550 Ti, which unfortunately cannot run the 2.5K resolution of my 32" monitor.
3. So I'm currently stuck on a 9-year-old computer with a slightly blurry non-native resolution & am trying to figure out if I just want to replace it with a used high-spec card or upgrade.
My computer is rock-solid. No TPM 2.0 chip so no official Windows 11, but Win10 doesn't deep-six until like 2025. I have a bunch of cards & storage drives. It's a 6-core unit with 64 gigs of RAM, so it's been a beast for quite a long time now. Only a standard 500 MB/s, not the new-fangled NVMe 4.0 7,200 MB/s-whatever chips available. But I'm pretty sure I could keep it going for another few years no problem, so maybe I'll just bite the bullet & snag a used mining card off fleabay to keep my system rolling.
Although that new 24GB 4090 Ti sounds nice1 Just not $1,499 nice LOL.
Shmee
8,313
3,177
What motherboard is it? It could probably support newer cards, unless there is some weird incompatibility or whitelist. But hard to say, depends on the board I suppose. Depending on your budget, a used 5700XT or 6700XT or 3070 might be good, if they would work. Even a new 6700XT is only around $400.
zinfamous
111,915
31,441
From what I understand, all of the GPU chips and boards for the cards in all of the world come from a single 3D printer in some dude's basement.
Reactions: Pohemi and Captante
Captante
30,354
10,880
So ..... you're saying OP has a chance? ;)
SKORPI0
18,500
2,426
BoomerD
66,527
14,910
True. When he finishes one, he walks it over to his neighbor's basement where it's rivited onto a video card.
19,203
TSMC manufactures the GPUs for Nvidia/AMD.
Nvidia and AMD have their own reference cards that are built by some AIB (add-in board) partner. You can get Nvidia's reference Founder Edition card from Best Buy and AMD's reference card is available from their online shop.
Then the AIB partners buy the GPUs from Nvidia/AMD and design their own cards with heftier cooling solutions/VRMs/capacitors so they can be overclocked easily and much better than the reference models.
At least, that's what I know. Why are you curious? Are we going to be looking forward to Gizmo Edition graphics cards soon?
