Are Gillette fusion and Fusion Power cartridges interchangable?
Status
Not open for further replies.
mwmorph
I was just wondering, are the 2 interchangeable and if so, what is the difference besides higher price? I have sensitive skin and thin whiskers so the low spacing on the blade works wonders, but I have a Fusion power so it costs quite a bit to buy new cartridges and for all intents and purposes, I couldn't figure out what is visually different between the Fusion and Fusion power cartridges.
Yes they are.... the only difference is the different color of the plastic and lubricating strip as far as I can tell. I have both.
Yes. I have a fusion power but I buy the regular fusion cartridges because they are slightly cheaper.
Good to know since I stopped turning on my Fusion Power last week... seems to shave better without the vibration. 😕
yeah, the only advantage to the vibration seems to be when you are rinsing the hairs out of the blades.
Yes, and I only know because i recently used the non-power cartridge with the power razor.
Status
