Are fuel system cleaning services scams?
virtueixi
2,781
Firestone "recommended" a "3-step" $90 fuel system cleaning for me. Anyone had any experience?
virtueixi
2,781
They just reccommended it as saying that my car has carbon built up despite the fact that they didn't open any engine components up. I only use bp or shell fuel.
FoBoT
63,084
15
fobot.com
so they use an xray or secret magic powers to spot the carbon on the inside?
sounds bogus , but i am not a motorhead
Atheus
7,313
Yea 3 step - step one, open fuel cap. Step 2, add fuel system cleaner. Step 3, close fuel cap.
BoomerD
65,702
14,101
There are different ways of cleaning your fuel injection system. For $90., I'd suspect that they will use an in-line bottle of fuel system cleaner, then dump a bottle of a cleaning additive in your gas tank. D0oes your car need this? Depends on the mileage, but probably not, IF the car was routinely maintained...Here's more info on the process:
http://www.repairtrust.com/fuel_inj.html
virtueixi
2,781
lol
IGBT
17,967
140
..black soot accumulates on the throat of FI throttle bodies. It will cause rough idle and stalling if it isn't cleaned of from time to time. I use carb cleaner and an old tooth brush to clean it off and I always notice a much smoother idle. I do it every oil change. The dealers do the same thing and call it throttle body service and charge as much as 100.00 to do it. Takes about 15 min to remove the air cleaner spray the inside of the TB scrub it wit the tooth brush..spray again. Install the air cleaner..finished. The soot accumulates AFTER the engine is shut off I'm told and all FI/TB's will accumlate soot.
OS
15,581
you need to clean your throttle body at every oil change? You should check your intake/air filter sealing.
Thorny
1,122
For a $90 service he should be getting a high pressure in line treatment. This is where they hook a bottle striaght to the fuel rail of your car to inject the solvent under pressure. This can be beneficial if you have a clogged injector that is creating problems such as rough idle or poor mileage. The only way to tell for sure if there is an injectory giving you probs is to test them independently off the vehicle, so this is not a sure fix.
I would only recommend this if your having a problem that been narrowed to the fuel system. If you're not already having problems this will not help you much, if at all.
jdoggg12
2,685
11
Did they at least offer a discount on the blinker fluid if you paid for this service?
BoomerD
65,702
14,101
They may indeed use such a system...IF they're reputable...
http://www.diynetwork.com/diy/ab_auto_f...ticle/0,2021,DIY_13679_2276265,00.html
