For example:
Sapphire Vapor-X on AMD or EVGA ACX on NVidia.
I am buying two new GPUs and have sort of decided that I will only buy from these two ranges of GPUs because their fans will last longer. I assume it is important that ball bearings will wear out less quickly because a worn sleeve bearing will make a lot of noise - right?
Also, are there any other GPU brands/ranges with ball bearings besides the above?
