Are ATOT forums load balanced?
TechBoyJK
16,699
60
I'm just curious how the forums are allowing time warps. If there are multiple front end servers processing the requests and their clocks are out of sync, then perhaps that could be causing the time warps? If the code to insert the replies is relying on the clock of the webserver and not the database server it is applying the changes to, or if there are multiple db servers and their clocks aren't in sync, that could be causing the problem..
Just wondering...... ... . .. .
Crusty
12,684
I think the answer lies in the fact that the forums are running Fusetalk. Take traditional logic and throw it out the door, because that's what the developers of it did with their brain when they decided to write the code.
nakedfrog
62,092
17,892
There isn't enough traffic here to require multiple DB servers unless they're old and crummy, or FT is coded badly.
Either way, it ain't hard to set up servers to sync time.
phoenix79
1,598
My understanding is that the DB server clock is out of sync with the Webserver causing the problem, but my opinion doesn't mean much
TechBoyJK
16,699
60
I know it's not hard, but I'm just wondering if that could be the cause. I've seen some pretty basic things get overlooked and cause big problems
TechBoyJK
16,699
60
Originally posted by: spidey07
Nobody is dumb enough to not be using NTP for clocks.
For sure. But.. How the fuck could time ordered inserts be displayed out of order? Timestamps can be very precise...
xSauronx
19,582
4
yeah i think you hit the nail on squarely on the head with that one.
her209
56,336
11
If the FT code is doing an SQL INSERT into the back-end database via ODBC or some other database connection using a call to get the time on the local server receiving the HTTP POST to pass as a function parameter, then the race condition is obvious.
OCGuy
27,224
37
They just need to heighten the load module and reboot the sychronizer. Maybe even reverse the polarity of the frequency gauge.
Everyone knows this.
Locut0s
22,205
43
They are putting all their work into the site redesign and switchover to vB, so they are just letting the current bugs go for now.
Rastus
4,704
This. They quit paying FuseTalk for support when they decided to switch. So they are a few updates behind.
rockyct
6,656
32
lol, how fitting. Crusty gets time warped in a thread talking about suggestions on how to fix the time warping.
Crusty
12,684
I didn't even try on this one either :(
nakedfrog
62,092
17,892
I can't imagine why you'd use anything other than the DB time, though.
manlymatt83
10,051
44
Same here.
But the better reason is most likely a mysql slave is out of sync with the master time wise, and the functions aren't deterministic.
alkemyst
83,769
19
If you don't get stingy with the reach-arounds, the perv mod gives you a time warp accelerator for your browser.
Oceandevi
3,085
Sometimes that causes more problems than it is worth. Duh.
MikeMike
45,885
66
i love timewarping... it allows me to go from hitting on a chick here on ATOT to already banging her without any other steps...
Crusty
12,684
O RLY?
Legendary
7,019
I'm not saying you're wrong, this would definitely cause warps, but who in their right mind would ever code something this way?
her209
56,336
11
Maybe it was never intended for it to be run on multiple front-end servers.
