Things always change in a few years time, so this is a question better left answered at that time. I'm not sure why you would select a CPU today to build in several years as unless you have a time machine, you don't know what your options would be.
That said, four case fans are overkill for just about every build out there. Many pre-built PCs like Dell and HP typically come with one case fan.
Do you mean 4 total fans (besides the one on the video card), or 4 case fans? That setup doesn't need 4 case fans.
4 total fans is just right, if speed controlled, and one is in PSU, one on CPU 'sink, one on case rear wall so CPU heat exits instead of going through the PSU, and one front intake to help create positive case pressurization for a filtered intake, and help cool HDDs if present, then you can block off the unused fan mounts so they aren't passive intakes for dust.
Some people, particularly gamers, might also put in a side panel fan to help cool the video card, especially if it has a weak fan that has to spin at high RPM by itself, and would wear faster as a result.
Depends on case design too. If talking bare minimums, the PSU fan and one more could get the job done, but then that 2nd fan would pull air past the CPU out the back, causing dust to come in every nook and cranny at a far faster rate, making every fan and heatsink less effective. Cleaning a filter panel is much better than cleaning out an entire PC.
It's not bad at all. It's just overkill for your build (e.g. not needed).4 case fans. Mainly for aesthetic but also to support the cooling process of the GPU. I so will have a HDD installed. The case will have three fa s upfront and one exhaust one in the back. Is this setup bad? BTW thank you for your answer.
That said, I have one exhaust and three intake fans on my computer (to run them at low RPMs to keep things quiet).
It will work but front and rear fans don't do as much for the GPU as a side panel fan, pointed right at it typically a couple inches away and blowing a little air over the back of the card helps too.
Acrylic side panels can be annoying to cut for a fan mount if cheap/thin/brittle but for metal, it's pretty simple to cut a hole. The worse situation is when they already put a fan mount in but in the wrong place and it overlaps where you want it!
In the past I've used cheap black plastic automotive door-edge trim to finish such cut holes. Inflation. This stuff was $2.50 last time I bought it. Maybe it still is in-store, online it has free shipping:
Cowles Black 3/8in Door Molding 2 Pack
Shop for Cowles Black 3/8in Door Molding 2 Pack with confidence at AutoZone.com. Parts are just part of what we do. Get yours online today and pick up in store.www.autozone.com
The type that has hot glue instead of a sticky tape liner, should be heated with a hair dryer and held in place until it cools. If you're using a filter panel instead, measure wisely and the panel itself may cover the cut edge of the hole.
