I'm looking for an 2.5" IDE SSD, but so far I'm not finding many affordable options. Surprisingly (to me), there are a lot more options in the 1.8" size, so I began looking into whether there were adapters available. So far, I haven't found anything, and then I came across the spec sheet for a SuperTalent drive that shows the dimensions and pin-outs of the connectors on the 1.8" and 2.5" IDE models to be the same:
http://www.supertalent.com/products/ssd_detail.php?type=DuraDrive ET
But I have not been able to find anything that confirms this. Can anyone here tell me if one of these 1.8" drives would be plug-compatible with the 2.5" drive it would be replacing? I believe some of the ZIF-style connectors use lower voltages, but the specs here say they are all 5V.
And if anyone has actually put a 1.8" drive in a 2.5" laptop bay, what did you use to hold the drive in place. I looked for some sort of carrier to adapt the form factor of the smaller drive so it will fit securely in the 2.5" bay, but again came up empty. Is it sufficient to just tape the drive down?
