Arctic freezer 7 Pro
RussianSensation
19,458
765
Originally posted by: swtethan
I do! I would hate to look at it when I stare into my case :D just my opinion.
hhhe I cant really consider ANY PC components as "attractive." About the only sexy thing are pics of random chicks on the GPU coolers like Nalu, Rubi, Albatron/Gainward girls and that Sapphire alien chick. Even then they face the bottom of the case :(.
In any event, who stares into their computer tower? ;) I definately would take function over looks for PC components. Maybe PC can be made sexy if used to describe sexual positions like "The Quad" or in phrases like "I'd love for you and your friend to SLI each other," or "Your Core was Phenomenal."
MichaelD
31,528
Ugly, schmugly. When used with Arctic Silver 5, it's 100% better than the stock cooler, and is about 80% as good as the Tuniq Tower for 1/2 it's price. :D I love mine. Works like a charm.
On a side note: I really don't like the pushpin mounting clips for Intel's 775 socket. They are too flimsy. :roll:
VinDSL
4,869
www.lenon.com
OMG!
THANK YOU!!! THANK YOU!!! THANK YOU!!!
I have long *felt* that Freezers are the ugliest devices in computerdom, bar none, but some ppl seem to like them, so... I keep my 'mouth' shut.
I'd rather own a Lian Li case with a toilet bowl brush for a cooler, than run a Freezer!
Hell, I'd rather have a Thermalwrong XP-120 eXtreme...
Anyway, thanks!!! I though it was just me! :D
swtethan
9,071
Originally posted by: mjrtoo
Curious what you guys use that meets your need for a sexy cooler.
If anyone considered anything on a computer sexy.....wow....
good looking is as far as I go
Boyo
1,406
I own one and never really thought it was ugly. It's just kind of there.
Howard
47,982
11
I don't see it. Even if I did, I wouldn't mind. Doesn't really look unattractive to me.
mjrtoo
120
Not far off my brother, I don't even consider computers good looking. What heat sync would you consider good looking?
swtethan
9,071
anything other than the two that have been mentioned, lol
Modelworks
16,240
7
You really need to get out more.
You have far too much time on your hands if your staring at the insides of your pc :)
PianoMan
505
10
I think CHEEP trumps good-looking. :shocked:
Had mine Open Box from the Egg when they were unloading them for $10 apiece. I should have bought two for my secondary. Anyone else buy their AF7 then?
And yep - it ain't super slick looking, but it does the job. Thing is, it's in my P180 while the Zalman is in the LANBoy. Dunno if I'd consider switching them...
PM
mjrtoo
120
Cheep...as opposed to cheap....
I would rather use the term bargin than cheap. Cheap represents poor build quality as opposed to bargin that represents cost vs build quality. The freezer 7 is a bargin.
VinDSL
4,869
www.lenon.com
This is a great thread!!!
Basically Freezer owners are a breed apart - the Flea Market shoppers of the computer world - and proud of it!
If Salvation Army made a HSF, this would be it... :D
Keysplayr
21,219
55
I'm thinking of getting one for my E6420. Are these Freezers quiet? Or do they sound like hair dryers?
VinDSL
4,869
www.lenon.com
You aren't getting it, bro! :D
This thread is about "looks" not function...
Freezers work great, just like the compressor assembly in a (ahem) refrigerator or a water fountain, but they're ugly as sin.
As long as you don't have to look at a Freezer in operation, it'll work fine for you - otherwise get something else!
Keysplayr
21,219
55
Thanks. I don't care if the inside of my case looks attractive or not, just neat. So I guess the Freezer 7 pro it is. Functionality before finesse. ;)
You guys must just be talking about solder on the six pipes sticking out the top. Other than that, the Freezer basically looks just like any other tower cooler.
