crazylegs
Hey all...
have just fitted this HSF to my PC as a replacement to a cheap (not even stock) HSF that i had on there!
interestingly i have noticed a reduction in my load temp about -10% from 46c --> 41c
BUT my IDLE temp has increased by 1-2 degrees c from 31 --> 33!!! think this is due to reduced airflow within case and the orientation of the HSF...
the thing is i can only allign the HSF so that the fan is blowing up towards the PSU or down onto GPU and bottom of case.. and not towards the back as i would ideally like 🙁
i have an ASUS A8N-SLi and the bracket aroung the CPU only allows the HSF to have the fan above or below the HS.... and i'm pretty sure i cant change this???
thanks
thanks
