Puppies04
I purchased an arctic cooling freezer 13 PRO about 8 months ago and thought I would let people know about a fault that has just developed on it.
Basically I noticed the idle temps rising a couple of days ago but didn't have any time to see what the problem was so I figured I would take a look over the weekend.
Well after removing the cooler I can report that the mounting bracket has snapped one side and has a hairline crack in the other, this is the part that the cooler screws too to hold it tight against the CPU.
I fully understand that this could have been caused by me overtightening the screws but it begs the question why would it last 8 months and then fail if this was the case. I figure a more likely scenario is the weight of the cooler (it does weigh almost a kilo) has caused this to happen. I have contacted arctic cooling to see if I can get a mounting bracket on its own without purchasing a whole new cooler and will update this thread with the reply but I thought it prudent to mention this to anyone thinking of buying this product.
