Today I got the Freezer Pro 7. It took a while to install because the way the directions show you to mount it doesn't mount on my ASUS P5N-E SLI because of the northbridge so I had to turn it on notch clockwise so the fan is pointing towards the northbridge. After getting it setup correctly I turned on my computer but i'm not seeing the decrease in temps like I thought I would. With the stock intel HSF my system was idling at 47c and at load around 53c. With the Freezer pro 7 i'm idling around 41c, 42c and at load around 48c. Nothing alarming but I was hoping to see the CPU in the 30c's like other people. I used the thermal grease that came on the heatsink which could be part of my problem. I also smeared it a litte bit when I had to pick it up off the CPU to turn it. Just wondering if anyone has some advice to what i'm doing wrong.
