- Apr 25, 2003
- 380
- 0
- 0
Arcrylic case is hotter than aluminum case right? But arcrylic case can't shock you but aluminum can right? thx.
also, is arcrylic case hotter than steal case? thx.
Originally posted by: dexvx
Aluminum cases being cooler than a similarily vented steel case is a myth.
Originally posted by: robcy
Its all about airflow. If you have none, then yes the aluminum will radiate heat faster than arcrylic, not that it would make a noticable diffrence. If you are ever in a situation in which the amount of heat radiating from a case will make the difference on weather you machine will fry then you have bigger problems to worry about. If you have the correct amount of airflow then either material will serve you fine. I have an totally see-thru acrylic case, and my temps did not move 1 degree plus or minus, and everything else is the same. Of coarse my fans make enought noise to wake the dead, and between them I have almost 200cfm intake and 200cfm exhauste. But it impresses the hell out of women, and the computer illiterate, and when playing a game with the surround cranked, you do not notice.
Loud fans are for Hardforum members and n00bs.
Originally posted by: Jincuteguy
you d idnt answer my question about whether acrylic case can shock vs aluminum case.
Originally posted by: mrgoblin
If theres static electricity on your aluminum case, and you get shocked, worry more about your computer parts than your finger.
so if I have an acrylic case, then I won't get shock from touching it eventhere's something wrong inside right?
i think they are SLIGHTLY cooler
hehe...
Definitely, but if you ground yourself, chances are you won't eve get shocked...
