I am interested in getting a setup that I can use to archive my favorite TV programs from my Dishnetwork system. I do a lot of taping as it is... but it occured to me, that with the advent of Mpeg4 compression, it was now viable to archive video to CD-R. Hi-Fi tapes are loss prone and about $1 each for good ones (the absolute cheapest I have ever seen them, usually around $2 each). 700mb Cd-r disks are now nearly free... I see 50 spindles of them for $15 or less routinely. I just bought one at office depot, no coasters from it yet (about 20 burned)!
Does anyone have experience with doing this? Here is my plan:
Buy a Duron 600mhz cpu and Abit Kt7 Raid, overclock it to 950mhz (or even 900, whatever I can get to work). This will replace my current celeron 333mhz on a P2l97, I need better speed for Mpeg4 compression. Then buy an ATI all-in-wonder Radeon. I want to capture in real-time to Mpeg2 (preserves up to 720 lines at 30fps). Then let my cpu run all night compressing the Mpeg2 down to Mpeg4 (according to Tom's hardware 11/1 is attainable with virtually no loss in quality). This should yeild about 110 minuetes of DVD quality on one 700mb CD-R. Since most shows aren't near DVD quality, I can probably get 3 43 minute episodes to one 700mb CDr. For shows like Dr. Who and the original Trek, I can likely compress them even further.
Personally, I'd love to have all of Babylon5 widescreen, all of Docotor who, Stargate SG-1, Highlander, all the star treks, and a lot of movie's off showtime. These would all fit in one case logic CD case!
I have boxes of VHS tapes as it is... and they are not very high quality (even though I try to tape in SP Hi-Fi when I can). Then making copies for friends is easy... and it is lossless! I don't worry about magnetic media degrading over time. Then once I can afford a 100gb HD (near future?) I can have ALL my videos just a clik away.
Then immagine the trading possibilities!
I'll email you episode 203-221 of B5 for epsiode 301-315!
I need all of black adder, will trade all of red dwarf!
Then when I get a two way sat system (this fall, fingers are crossed) I can just ftp my brains out... and hopefully others will be doing the same.
Basically what .mp3 did for audio, this will do for video. unfortunately I will have to automate it (recording fom Dishnetwork, mp4 compressing) or else it could be tedious.... and compressing one 43 minute television program will take a 950mhz duron several hours
But the end result would be SWEET
There is one problem to this right now that I have ran into. There are several reports of AMD Cpus not being compatable with Mpeg2 or Mpeg1 real time capture. This boggles my mind... why aren't they? Can someone confirm and perhaps point me to a good article?
Also, it is possible to edit mpeg2 at all? I don't need to interject effects or titles... I just need to snip out the comercials
I'd appreciate your thoughts and advice. Will I just waste my time? Should I stick with video tapes?
Thanks!
Brad
Thanks!
Brad
