I've been away from PC news and construction for so long that I have NO idea what any of the current components are and how they perform, so I come to you fine gents for help!
I'm a 21 year old architecture major looking for a new workstation that will be more than I need for what I want to do and will last without struggle.
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Will be doing high-end architectural applications as well as digital art. Software being used will be heavy 3D rendering in Revit, Rhino, 3Dsmax, Sketchup and so on as well as doing digital art in Photoshop CS4, Illustrator CS4, Corel Painter X and so on.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Not sure. Whatever will do the job now and for several years to come, leaving open the ability to upgrade, but not making it necessary to upgrade very soon. Your good judgement is good enough for me.
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
No brand preference. I prefer quality and ability over logo, but that does not mean I'm cool with shady off-brand companies that just started 3 weeks ago.
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Edit: Only looking for computer parts, already have case, keyboard, monitor, etc.
6. IF YOU have searched and/or read similar threads.
Outdated results and lower requirements, but yes.
7. IF YOU plan on overclocking or run the system at default speeds.
Defualt speed - have had no previous experience with OC aside from BFG Tech video cards.
8. WHEN do you plan to build it?
June/July
Thank you all,
Ian
USA
June/July
Thank you all,
Ian
