I have decided to do a freshwater tank for the first time in years. Always small 10G tanks as a kid so I remember a little. I want to go 55/55 gallons to start with. Plan on a community tank and have some questions if you don't mind.
1) How beneficial are plants other than looking better than fake ones? Do they require more maintenance, etc?
2) I was considering an Emporer 280/400 Bio Wheel Filter. Is this sufficient or do you really recommend a canister filter?
3) When using a power filter like the Emporer, do I need an airstone, setup as well for aeration or will the filter be sufficient?
4) Do I need any other type of device to make the water flow more?
5) Do I need a U/V filter?
6) What type of lighting is sufficient for a 50/55 gallon tank?
7) How much maintenance per week would you say you do? I certainly plan on typical 20% water changes weekly with the Python grazel siphon which I hear is great. Any other major maint I should be aware of?
Thanks all.
Thanks all.
