Aquagate Max
Krish14
7
Hey guys ne1 gttng 1 of these things......
its damn cool,..my dist got 1....buying it it wen its launched...ll put up photos of it in my Stacker 830 case....
DerwenArtos12
4,278
It does look cool, I'll give it that but, selfcontained water cooling set-ups like that really don't perform on par with custom ones historically.
aigomorla
21,065
3,565
read my sticky under mixing metals
Then look under wiki for galvanized corrosion.
Heres something i noticed on the spec sheet. Obvious cuz its probably a cheap self contained unit.
Water Block Material Copper
Radiator Dimensions 300 x142 x 71 mm
Radiator Material Aluminum
You want my opinion on it? Absolutely Thumbs Down!
PCTC2
3,892
33
Well, maybe if he replaced the rad with a Swiftech MCR220, but at that point I'd say build a custom loop. Way better performance for the price. Plus, I like the look of customs better than self-contained, even if they are not as clean looking.
But this link is a lot more useful :p
DerwenArtos12
4,278
QFT on the link :D
But, replacing the radiator really defeats the point of having an all in one system don't you think? plus it's throwing another $40 onto the cost of this thing which will probably get you pretty cost to just building it from scratch with a mcp355 without a top and apogee gt or xspc block and you could just get the 320-qp with the built in res.
PCTC2
3,892
33
QFT on the link :D
I would say I agree with you, but I already said it. :p
DerwenArtos12
4,278
QFT on the link :D
ah, but, you're not saying you disagree with me :D
Krish14
7
the problem here in india is we gt only cm products here...n its a big hassle gttn other brands...
i already have 1 s1....damn gd performance....
da specs read 600watts of cooling.. think its more than enuf for 2 ultras...
DerwenArtos12
4,278
Don't always believe manufactureres specs, especially pre-launch ones. IMHO a good air cooler, even the hyper212 would perform on par with a setup like this so long as your ambients are below about 25C.
aigomorla
21,065
3,565
shoppts.com
Jab-tech.com
Performance-pcs.com
US based stores which i know ships internationally.
Theres a few UK stores, but i think there prices will be higher.
thilanliyan
12,042
2,257
Please use more vowels. :p
