AquaComputer Modularity Rad review.
Nemesis 1
11,366
It as I told you folks nothing can touch these rads in heat removal . These guys got a bit differant flow reading than did I but not alot within reasoning.
Ya Want the best here it is . My test was conducted with the 360 single also. I won't go into the flow thing at this time as I choose not to . First I have to go get all those post from a time past . Just to show you wonderful people how badly ya been deceived . I got something here that I am not suppose to have . I also seen a test result of the cpu water block . I have to get another block just to double check but someone is lieing and I can prove it . Well known tester to . LOL if ya give some people enough they will say whatever you want .
If any tester out there wants to test a aquacomputer 21558 kyros XT silver addition I have one . Oh and its good its really good . The best by far .
Heres Rad review
http://www.pureoverclock.com/review.php?id=1433&page=1
janas19
2,313
Very nice rad. :thumbup:
Although you could use maybe some lessons in writing, I haven't a clue what you mean to say :confused:
Nemesis 1
11,366
Ya I can be real hard to follow. It has to do with the testing of water cooling hardware . When I get like this it usually means I up to no good. Lol
Thank you subtec for posting the link over at XS. I love when a plan works.
Nemesis 1
11,366
Look at crazy nemesis quote himself . You guys should be more able to understand , With my quote above and the other things I was referring to aren't silly stupid things . One has to be carefull is as not to hurt an innocent . I have tested the 360 the 420 and the 240 Aquacomputer rads and This review is inline with our numbers , I can't and won't publish those numbers . I don't sell watercooling parts I sell only complete systems I have no interest in helping others to get to where were at . I stand to make no money selling watercooling parts . So I just don't publish our results . Point is I went back to XS water cooling forum hoping I got a bite . I did I did and here is what the man has to say .
I leave it to you folks to decide for yourselves.
Here is a reply to the Aquacomputer Rad thread at XS .
Test setup notes a "26L" reservoir. 26L=7 "GALLON" reservoir.? A 7 gallon reservoir would probably take hours to reach equilibrium. Noted that test was only run for 30 minutes??
Inconsistency between readings SR1 vs RX360, about the same at 0 and 1800, but more than a degree difference at 600??
Setup notes heater safety switches were not removed. I couldn't get a test done right without removing mine. Perhaps a different heater, but I found the switches would interfer and kick on/off throughout testing and had to be removed.???
Kaze master RPM manual control. My Kaze master reads about 50 rpm high and only has about a +- 50 RPM incremental reading. How were RPMs held constant????
0 RPM 315W results? I tried a passive TFC480 test with only 100 watts which failed to reach equilibrium after a couple of hours of logging data. I had to shut down the test and call it failed as temps reach beyond 50C. How can a triple rad do three times that heat with just a 13C delta? I don't think that's possible unless the radiator was in a case with other fans helping somehow.?????
Looking back at skinnees and swiftech's data, the MCR320 should have roughly a .04C/W for 800-900 RPM fans for good flow rates. That's about 13C with 8-900 RPM fans at 315W, but they are showing a 13C with 0RPM???????
What type of thermal probes and what controller was connected to those probes?????????? .
As I said in the quote I love when a plan works even tho I wanted this guy to do the test. It was clear there was a reason he didn't test . Its as I thought or sure seems to be . Also at XS same section a review of lastest water block . LOL at that review I know better. Than read on to how he wanted to test the lastest Aquacomputer cpu water block but wanted to move on to Rads . I can tell ya straight out why he didn't test it . Its the best block on the Market . Than go read the Fan shroud test he did LOL . First off and I am embarressed for these people if you widen the gap between the fan and the Rad fins . Thats not a shroud and is not intended to be one and a 1" gutted fan to be so called shroud is insanity.
First off in the PC world or any other that area between the fan and fins is called a spacer not a shroud the proper name would be What? Any guesss. The point is for a tester who has never tested this rad he has alot to say . How much do you cost . No price buys me . whats your guys sellout price?
Kenmitch
8,505
2,250
It's does look like a nice rad for a high end setup with alot of flexibiliy to boot....Damn too expensive for me :(
Nemesis 1
11,366
That was my thought also My wife bought hers first did a 2 rad setup 360 and 240 . Turned out great looking and it should have for what painting cost . Than I did my cousins machine . Same as wifes no paint tho .
Mine is almost done waiting on IVB and cousin gets IB also . But On mine I measured the room I had . According to wifes measurement 420 won't go in . But my measurements said yes it will . So I got the 420 dual loop . Watch what I do with that 30% going to the cpu . LOL . So 1 rad for the price of 2 it actually was about = in price to 2 other brands of rads.
Oh that post over at XS post 234 I bekieve as he edited it . But after i got it here first. LOL . He must have seen how badly he misread the review. Or its as I think there be more here than meets the eye
OVerLoRDI
5,490
4
Fantastic looking radiator with epic performance. Maybe someday, but for now I'm happy with my EK XTX 360 and XTX 120. On top of that I have an MCR320, Black ICE SR-140, and 2x magicool slim 240 rads. The last thing I need is MORE radiators :p
