I am in the process of putting together a watercooling system. I have the following parts:
Aquastealth Aquacoil Radiator
Dangerden Maze2-1 Water block
Resepump Internal Mount from Caseetc.com
Silicone Tubing from Dangerden
I'm getting a small leak from the aquacoil on the connection to the radiator. Its fine unless I squeeze the tube. I'm worried that if it gets moved a bit in my case, it may leak. Also, The Pump is leaking from the small hole that is used to fill it.
I'm not using any hose clamps right now, and I think i may need to pick some up 😉 Any suggestions on what to do, or anyone with aquacoil/resepump experience would be appreciated.
Thanks,
Ryan
Thanks,
Ryan
