Borrowed this from one of the other threads:
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
gaming, family use.
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
Prefer between $800 - $900
3. What country YOU will be buying YOUR parts from.
US
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy,
ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc.
none
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
none
7. IF YOU plan on overclocking or run the system at default speeds.
No, probably not going to OC - just run at default speeds.
8. What resolution will you be using?
Don't have a high tech LCD Monitor, it's just a 22" Staples brand, probably can't go above 1920 x 1200? or so?
9. WHEN do you plan to build it?
After I get all the parts, this spring if possible.
10. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Windows 7, and probably MS Office for Home/Student, but will only factor in OS for the above budget pricing.
Will use the PC for primarily moderate gaming, FPS but not bleeding edge stuff. Been playing on a AMD2 dual core rig with 4 GB RAM, and an old nVidia GForce 9600 graphics card and integrated sound. Can't play MW3 on the old rig so I need to upgrade.
Core items Need the following:
Power supply - YES
Case - YES
Motherboard - YES
CPU - YES (a 2nd gen i5 or AMD equivalent. Would love an i7 but dont think my budget can take that.
Heatsink/fan for the CPU - YES
Memory - YES (6 to 8 GB I would hope)
Primary hard drive - YES (Doesnt have to be SolidState) preferably at least 1TB with space in case to add 1 or 2 more HDDs)
Primary optical drive YES DVD-RW at a minimum. Probably will upgrade to BR when prices drop drastically (Budget issue again)
Video card (unless you?re using onboard video) - YES, dont want to rely on on-board vid card.
Operaing System - YES, Win7 Home or Pro, 64 bit if possible, whatever will fit in budget
Additional software - YES, probably Home/Student version of MS Office but probably have to put that off for budget current constraints
Let me know if you have any additional questions and thanks in advance for your counsel.
gaming, family use.
US
none
none
Power supply - YES
Case - YES
Motherboard - YES
