Application to Control Hard Drive RPM Speed
dabench
465
Hi, I'm looking for an application that will allow me to change the RPM of my hard drive. I have a 7200 rpm hard drive but I would like to slow it down to 5400 rpm. Can you recommend a good app? Thanks
thecoolnessrune
9,673
583
No such application exists. It would take extensive firmware changes for a hard drive to read and right at *any* other RPM than it is designed around. It's just not in the nature of the beast for hard drive RPM to be controllable.
dabench
465
No I've used these kind of apps before I just can't remember the name of the app I used.
thecoolnessrune
9,673
583
Are you talking about an application that attempts to more aggressively shut off the hard drive when it's not being used? Because we still assure you there is no hard drive RPM reduction. It's simply not possible to do in an app. It would take extensive hard drive firmware reprogramming and evne then most hard drives simply aren't going to be able to do it. They are designed around running at that constant speed.
Your best bet is to sell off your existing drive and buy a 5400RPM drive. You should be able to at least break even since 7200RPM drives go for a premium. Heck if you have a 500GB notebook drive I might be willing to do an even trade as I'm looking for moving up to a 7200RPM drive :p
mpilchfamily
3,559
If having a slower drive is that important to you then buy a new drive. WD has there Green line of HDDs.
dabench
465
I'm actually doing this for research so I need to use the same drive.
Again I've used the app before I just can't remember than name. It is possible so please stop telling me that it is impossible. I know what I've done before.
VirtualLarry
56,580
10,217
Well, and I'm telling you this as nicely as possible, you're wrong.
corkyg
Elite Member | Peripherals
27,370
240
Maybe OP is thinking of Automatic Acoustic Management of HDDs to make then run quieter?
piasabird
17,168
60
I have seen some programs to slow down the processor for things like emulation to run programs slower. If you want to go slower buy a slower Hard Drive. Might also get a slower processor to begin with.
