Hi,
I recently upgraded my system entirely but kept the same hard drive albeit with a clean install of windows. It takes about 40 seconds for Windows to load after post on my e6600 (401x9) p5b-e plus with 2GB DDR6400, 8800gts. I don't run a ton of background processes, only the same as I had before on my A64 3200, nforce3 ultra, 1GB DDR3200, 6800 system. I'm sure windows used to load faster.
My hard drive is a 200GB sata150 drive. The mobo is set to auto detect. It's calling it an ide, is that correct? I told it to use ahci but it crashed on boot, is that a setting you only use for raid?
Load times in general seem just as slow or slower as they were on my last system, in fact loading a level in half life 2 seems to take longer as well come to think of it. Can anybody explain this or think of a remedy? I've put the drive in a different port and defined the PIO and udma settings myself and it still won't go faster.
cheers
cheers
