Ok, speed dropped again while transferring files so my 2 switch theroy and bad cable seems to be eliminated. I installed an Intel Pro 1000 in this box in the belief that it was superior to the on board Realtek. it may be but it also seems to be defective. I did notice that after moving the box I had to push in on the nic to get it to work at all. i thought nothing of it because I figured it creeped out of the slot during the move, even though it felt fully seated when I pushed on it. Anyway, after the push it started working. I then proceeded to transfer the files and at first, it started out at about 98MBs but then dropped to 11MBs after about 20 seconds. I've removed the Intel NIC and re enabled the on-board Realtek. So far so good but only time will tell. Just checked and speed has dropped to 50MBs. Guess I can live with that but not 11MBs. 🙁
Also, none of the cables are homemade.
