- Aug 25, 2001
- 56,326
- 10,034
- 126
APC BR1000MS 1000 VA Pure SineWave 10 Outlets 2 USB Charging Ports Back-UPS Pro Battery Backup
+ $25 off w/ promo code 6BGSALE235, limited offer
Are you a human?
www.newegg.com
Got an older UPS? Maybe time to "step up" to a "Pure SineWave" UPS, to work properly with modern PFC PSUs in PCs? Don't have a UPS, and decided to get one? This is the unit for you!
I own two of the 1350VA "Pure SineWave" APC consumer units like this one, they work great! Have had them for over a year now, I think.
Edit: Important, make sure to get a UPS with enough "Watts" to handle your PC. "VA" doesn't really mean much, in this context, even though it may technically be correct. This UPS is ONLY 600W capability, so if you have a larger than 650W PSU, or even lower, but draw 600W or over (or even close to it) at the wall, you need a BIGGER UPS. Hence the reason that I went with the 1350VA model. That, and the 1500VA model was a bit pricey.
Edit: Don't forget your peripherals when sizing your UPS, including your monitor. My 40" 4K UHD TV takes up to 100W or so, alone, and I've got a few USB hubs and USB peripherals that probably take 15-20W too.
So if my dual-GPU 6C/12T modern PC takes 400-450W at the wall, PLUS, 100W for monitor, PLUS extra overhead for peripherals, then yeah, I'm glad that I went with the 1350VA / 810W (?) model.
Also, just because your PC has a "750W" PSU, doesn't mean that it takes 750W all the time, but be aware that due to efficiency issues, there is an increase of effective wattage AT THE WALL. Best to measure actual power consumption with something like a Kill-A-Watt meter if unsure, or just buy the next size bigger UPS. (Note that most if not all UPS units with an LCD display, can tell you not only stats about your AC line input, but also your load you're putting on it.)
APC BR1350MS 1350 VA Pure SineWave 10 Outlets 2 USB Charging Ports Back-UPS Pro Battery Backup
Additional savings w/ promo code 6BGSALE235, limited offer
Are you a human?
www.newegg.com
Shows as $149.99 in-cart, after applying $25 promo code. So if you didn't use the promo code already on the 1000VA model, it now applies to the 1350VA model, which I would strongly recommend instead for most modern gaming rigs. (I use the 1350VA models myself.)
