Aopen ax34proII/cel2-633octo 950- Problems
jazzisjazz
272
Hi all,
I am trying to get this combo to work.
I have tried setting the fsb jumper range to 100-124 and when i do it will not boot. i have bumped the voltage up to 1.80v. still no go. what should i look at first? should i expect any response without bumping up the vol5tage more? how much is safe for this cpu?
If anyone is familiar with this board or has done this successfully please respond.
cel2-633w/golden orb
aopen ax34 pro II
128 meg pc 100
ibm 10g 7200
sb live
40x cdrom
hp 4x/24x cd-rw
zip 100
usr 56k winmodem
win 95
300w full tower, 3 fans:confused:
Gandalf90125
107
With your motherboard running at 100MHz, your CPU would be running at 950MHz.
It could be that your Celeron just cannot handle that speed.
I would suggest starting at something in the neighborhood of 83MHz FSB--which should be easily attainable with your motherboard, CPU, and RAM--and perhaps working upwards from there if the AX34ProII supports a speed between 83 and 100 (which I think it does).
jazzisjazz
272
Thanks Gandalf90125,
I tried the 83mhz bus setting so I'm currently at 791. There is no setting for me between 83 and 100mhz so I'm still wondering If I have some setting wrong. I have been up to 2.05v (my max setting with no luck). Assuming it were an agp related problem could i stick a pci vid card in for a cure?
Thanks Again,
jazzisjazz :)
