AOPEN AK77-8X Max - Problems !!!
andersgoransson
12
My AOPEN AK77-8X Max with 1800XP shuts down direct after start and beeps. Never heard this type of beefs before but
it sounds like a "didodidodido" :) and fades away .. anyone have a clue? The Dr. Voice thing dont say anything ..
Tried remove everything but the cpu and the mems but it´s the same thing.
// AWD
mechBgon
Oct 31, 1999
30,699
First idea: could your CPU heatsink be reversed 180°? That would cause a very rapid thermal spike and cause the board to cut power to the CPU. The heatsink has a step cut into the base: picture The step must be at the end of the heatsink that the CPU doesn't cover, the plastic part. I've seen some recent retail AMD heatsinks with a copper heatspreader plate screwed to the base... same concept applies.
If you have a heatsink that comes disassembled, you could get the heatsink on right but reverse the clip, resulting in a similar issue.
Another possibility is that the CPU-fan header on the motherboard isn't picking up an RPM signal, which I'll check into. What kind of heatsink/fan combo do you have there? Stock AMD one, or ???.
mechBgon
Oct 31, 1999
30,699
A look through the manual doesn't reveal any SOYO-esque setup where the board won't run without RPM signal on the CPU-fan header, so I doubt it's that. Pretty groovy manual, by the way :D Good luck, I hope something comes to light for you :)
andersgoransson
12
Alright, will check the heatsink .. it´s the one that follows the cpu .. noisey thing but that does´nt madder in whis case...
Megatomic
20,127
Originally posted by: Viper96720
thank goodness for these newer amd boards with thermal monitoring
You got that right. I cringed when I read his post above. :D That would have been a dead CPU not long ago.
