AOLIM Question - w/Direct Connect
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
Hey,
Just wonderin if anyone knows how to fix the problem of gettin a direct connection going sometimes... With most people i get this error:
XXXXXX has cancelled request due to no response from you; no connection was made. (If you and your buddy are each behind a different firewall, then the connection will not work; check with your network administrator if you are not sure about your firewall status. You should also try going into the Talk or IM Images sections of AIM preferences and toggle the 'Use Address' option.) (11:06:44 PM).
We both get the same responce... Is there a port on my Linksys Cable/DSL router that i need to open to allow this? Anyone know?
