- Sep 13, 2001
- 53,717
- 6,590
- 126
So the other day I realized that what I thought was a degaussing issue with my KI2 cabinet was actually because it's close to my surround speaker.
I pulled my cabinet out from the wall next to the speaker, and what would you know, the discoloration went away.
I tried putting a sheet of steel sheet metal around the side of the cabinet but unless it was in a very specific place, the distortion was there. And even then, I think it was still there just not quite as bad.
Today I messed with it a bit more.
I need to remove 2/3 of the drivers to completely remove any interference. If I kept that middle one in there, then it still was having a little bit of distortion.
Here are pics of the drivers. The one on the left is the center driver. The one on the right is the outer one and is identical to the other outer one. It looks like the one in the middle has something on the rear of it that plugs into some wires inside the speaker. I'm guessing it's a little tweeter driver but I'm a noob with this so that is just me making an educated guess.
Also, the driver appears to be 5.25" in diameter, and the magnet is pretty dang strong lol.
Here is the rear of one that goes in the center with what I think is the tweeter on it.
And here is the rear of the one that is on the outer side.
I had heard of this thing called a bucking magnet but I don't think that can work with the middle one because there is a tweeter on the rear of it so I can't get another magnet back to back against it.
I have emailed JTR (speaker manufacturer) directly as well to see if they have any ideas or sell shielded drivers I could replace these with so we'll see if they have any ideas.
Anyone else have any other ideas on how I can get this shielded so I can keep it in the current spot?
