Anyway to Relocate Documents and Settings?
corkyg
Elite Member | Peripherals
27,370
239
I have found out why my C:\ drive keeps growing - it is because of the Documents and Settings folder which all apps seem to like to keep junk in. It causes constant changes which result in constant fragmentation.
I would really like to place that folder on my data drive and get it away from the O/S.
Thoughts?
corkyg
27,370
239
Thanks much, Mike. I sort of suspected that was the case. I have three duplicate drives, so I can afford to play around with one of them and see what happens.
I was able to successfully relocate C:\Windows\Temp and \Tmp. No problem with that. I was hoping it would be as easy.
Thanks again!
ShadowBlade
4,263
you cant move the docs and settings folder easily, but you can make the my documents icon point to someplace else
