Originally posted by: aphex
Never been able to get this thing to work...
Logitech MX Duo, can never get into the Bios using it....
Any ideas?
Any ideas?
Have you tried setting the legacy usb controlled by Bios not OS option in your bios?
most boards have this option in your bios,after you enable that it should work.
Originally posted by: John
I have a Logitech MX Duo on my other rig connected thru the USB port, and I can access my bios just fine with Legacy USB enabled. Worst case scenario grab a wired keyboard to configure it.
