Anyway to connect Playstation to a Tv tuner card???
SoCalConman
42
I am moving off to college on sat and wondered if there is any possible way to connect a Playstation console to my ATI TV Wonder card. Thanks.
Raincity
4,477
12
you dont need no coax to connect them,just plug the Playstation audio and video outputs into the tv wonder video and audio inputs. then run the tv tuner and select composite input and you ready to go.
Rain
SoCalConman
42
Do I need some sort of adapter for the audio output from the PSX to the TV Wonder audio input? Because as far as I can tell, they are not compatible.
Raincity
4,477
12
Yes you need the 1/8 stereo to two composite input stereo adapter. Mine came included with the card but if your missing yours, you can buy one at Radio Shack for under 5$.
Rain
