anything to do with a motorcycle tire with a tiny hole?
bmacd
10,869
i just got a popped motorcycle tire (dunlop d207 55r17-180) and replaced it with the same tire (despite the d207s are being replaced with the 208s shortly). Can i sell the tire to anybody (again, the tire has a small hole the size of a q-tip head in the center of the tread) or should i just pitch it? Other than the small hole, it only has 500 super light miles on it with almost full tread. It seems a waste to pitch a perfectly good (well, sorta) tire, so....
-=bmacd=-
Mutilator
3,513
10
I know you can plug car tire holes... but I wouldn't want to take that risk when you only have 2 tires under you. ;)
bmacd
10,869
i'm not looking to personally re-use the tire. Riding on a plugged tire is a death trap.
-=bmacd=-
Zenmervolt
Elite member
Oct 22, 2000
24,514
36
And yet you're willing to sell it to someone else? It's not going to be any safer for them you know. Pitch the tire.
ZV
bmacd
10,869
ZV
i thought there might be a company that can re-manufacture the tire without melting it down or professionally melting in a new section.
-=bmacd=-
