happy medium
Recommendations or links are helpfull .thanks
Originally posted by: canadageek
try a peltier cooler witha water block on it. it uses an electric current to draw heat away from one sode, and dissipates it from the other. they're fairly cheap, and can cool below zero C (not sure of actual numbers) they should run on 12V too, so you can plug it right in to the power supply. the watercooler dissipates exces heat from the hot side of the peltier.
they should be cheap, aroun 30-50 dollars, i think
Originally posted by: ribbon13
I have a dually, so going phase change wasn't an option without a lot of time I didn't have. So I got dual TECs, and each one takes a PSU.
http://sidewindercomputers.com/dopro36.html
http://sidewindercomputers.com/bldopro43for.html
http://sidewindercomputers.com/blicextiiitr.html
http://sidewindercomputers.com/mese6024vsio.html
