Anyones Wireless Network interfere with their wireless mouse?
aphex
Moderator<br>All Things Apple
Moderator
Jul 19, 2001
38,572
I notice that since i've moved my wireless router closer to my wireless mouse, it seems to freeze alot more often and occationally completely lose its signal...
I dont believe that the mouse runs on 2.4ghz, so am i nuts in thinking it could interfere?
thebestMAX
7,519
140
I have a wireless Microsoft Router and a Viewsonic wireless mouse and keyboard.
No problems here and I tried to induce them by putting all three recievers next to each other and my cordless phone there also.
May be another unshielded source causing your problem or even your hard drive. Check your grounding if wiring in house is old also.
aphex
Moderator
Jul 19, 2001
38,572
For some reason, as soon as i set up my triple monitor setup and had to rearrange my room a tad, my wireless mouse's signal gets sketchy from time to time...
hehehehe..
at my uncle's place if they pick up the cordless the wifi connection drops...
they cordless is in a different room from teh wifi router.
What a bitch i tell you. We tried changing channels on both ends.. it got a bit better but it still screws up.
Best of all it doesnt matter where you use the cordless.. as long as it's on.. you loose wifi connections.
