Mines starting to act up, same symptoms as my sisters whose completely got stuck. I hear Samsung is fixing these even out of warranty because it is just a common problem. Is that true? How have you guys fixed it yourselves?
the actual physical button you push is fine, it doesn't get physcally stuck. it seems like an internal problem inside
but thank you for the tips I will try that
