Anyone with a Lian-Li Case...
salz
188
I have a Lian-Li PC-65 case and a case temp. of 41 degrees celsius. I want to drop that temperature and I know that if I have more powerful intakes it should help. Has anyone with a Lian-Li case replaced the intakes? I was looking at the intakes and I was just a little worried because of how they're connected to the chip that is also connected to the power and hard drive lights. I want to replace the wiring so that I can give more power to the fans (currently, the fans only have the yellow and black wire giving the fans less power, although making it quieter). Am I able to change the intakes? Thanks.
KouklatheCat
1,502
I have a PC 60 series Lian-Li. I changed out my exhaust fans and got better cooling. The yellow wire on a molex connector is the 12v line and the red is the 5v line. I am going to upgrade my intake fans soon. I plan to ditch the switch and run them off of a molex plug.
