Anyone want to help with math?
minime72706
86
I know I should do my own homework but I suck at it and I'm trying.
so y'=(x+y)/x y(1)=1 Every time I try to do this I wind up getting y=(3/2)/x-x/2.
I get y'-(1/x)*y=1 solve using the integrating factor.
I have the answer for y(2) using Runge-Kutta so I know my answer is wrong.
Can anyone offer some guidance on why I suck at this? Thanks
JM Aggie08
8,364
960
i'm about sick n tired of ppl showin off they're fancy math problems.
i'll take ax^2+bx+c over that mess any day!
Cawchy87
5,104
Yikes, I haven't done this for a few years and totally forget how to do it. Bump! Hope you get an answer!
TecHNooB
7,458
Ok, this is a homogenous equation. To determine this, all you have to do is verify that:
f(tx,ty) = f(x,y)
To solve the equation, let v = y/x (also y = xv) and reduce to a seperable equation.
If you take the partial of y = xv with respect to x, you get dy/dx = x * (dv/dx) + v.
So.. replace all the y's with xv.
dy/dx = (x + xv) / x = x * (dv/dx) + v
[x * (1 + v)] / x = x * (dv/dx) + v
1 + v = x * (dv/dx) + v
1 = x * (dv/dx)
(1/x) * dx = dv
Integrate both sides
ln(x) + K = v
ln(x) + K = y/x ~(v = y/x)
y = x[ln(x) + K]
y(1) = 1
1 = ln(1) + K ------> K = 1
y = x[ln(x) + 1]
I hope this is the correct answer ~_~
CraKaJaX
11,905
148
101
f(tx,ty) = f(x,y)
1 = x * (dv/dx)
(1/x) * dx = dv
ln(x) + K = v
y = x[ln(x) + K]
y(1) = 1
y = x[ln(x) + 1]
If that's correct, he said he has the initial condition y(2) = ...?
Plugging in 2, and assuming your y is correct, that would mean y = ~3.4?
minime72706
86
y = x[ln(x) + 1]
Thats the right answer. y(2)=3.38 which is what I get with Runge-Kutta which is supposed to be within .01.
Thanks a lot. I just don't remember seeing it being to that way in class. The separation I get the substitution not so much, but I'll try to figure it out.
Aug 10, 2001
10,420
y'=1+y/x
y'-y/x = 1
now multilpy both sides by 1/x
(1/x)*y' -y/x^2 = 1/x
d/dx(y/x) = 1/x
y/x = ln(x) + c
y = x*ln(x) + cx
1= 1*ln(1)+c*1 =>c=1
y = x*ln(x) + x
CycloWizard
12,348
The accuracy of Runge Kutta completely depends on which RK formula you're using and the discretization used. And the DE isn't homogeneous, since (x-y)/x=1-y/x. It's first order linear and can be solved using integration factors.
robphelan
4,084
17
yeah.. so take that!
Fenixgoon
33,116
12,527
man, i used to know ODE's like a mofo. oh how quickly things change in two years :(
