AznMaverick
basically, i need a function that will come up with 32 unique hashes for 32 words. these words are: auto, break, case, char, const, continue, default, do, double, else, enum, extern, float, for, goto, if, int, long, register, return, short, signed, sizeof, static, struct, switch, typedef, union, unsigned, void, volatile, while.
the program that i am using to try and find values for my hash function looks like this...
#include <stdio.h>
#include <stdlib.h>
void read(void);
void compare(void);
int Hash(int key);
int exp(int base, int exponent);
char string[1023];
int max_entry;
int hash[255];
int bingo;
int step;
int exp_inc;
main() {
int i;
max_entry = 0;
string[0] = 0;
bingo = 0;
step=1;
exp_inc=2;
read();
printf("\nEntered is: ");
for(i=0; i<max_entry; i++)
printf("%c", string);
printf("MAX ENTRY is %d", max_entry);
printf("\n\n\n");
while(!bingo) {
Hash(1);
compare();
printf("\nHash values are: ");
for(i=0; i<32; i++)
printf(" %d ", hash);
printf("\nStep is %d\n", step);
printf("exp_inc is %d", exp_inc);
printf("\n\n\n");
int Hash(int key) {
int i = 0;
int number = 1;
int count = 0;
step++;
for(i=0; i<max_entry; i++) {
if(string=='\n') {
if(number < 1) number = number * -1;
hash[count] = number % 32;
// printf("\nHASH is %d\n", hash[count]);
number=1;
exp_inc=1;
i++;
count++;
// number = number + ((step)* string);
number = number + ((exp(step, exp_inc)) * string);
exp_inc+3;
//exp_inc++;
return step;
void compare(void) {
int i;
int j;
int increment = 1;
int track;
for(i=0; i<32; i++) {
for(j=increment; j<32; j++)
if(hash==hash[j]) {
// printf("\n%d is the same.", hash);
bingo = 0;
return;
increment++;
bingo=1;
return;
int exp(int base, int exponent) {
int i;
int number = 1;
for(i=0; i< exponent; i++)
number = number * base;
return number;
void read(void) {
char entry;
int i;
i=0;
while((entry = getchar()) != EOF) {
string = entry;
i++;
max_entry = i;
return;
basically, what it will do is keep going in a loop until the hash function comes up with a unique set of hash values for each word. Any other suggestions?
#include <stdio.h>
#include <stdlib.h>
void read(void);
void compare(void);
int Hash(int key);
char string[1023];
int max_entry;
int hash[255];
int bingo;
int step;
int exp_inc;
main() {
int i;
max_entry = 0;
string[0] = 0;
bingo = 0;
step=1;
exp_inc=2;
read();
printf("\n\n\n");
while(!bingo) {
Hash(1);
compare();
for(i=0; i<32; i++)
printf("\n\n\n");
int Hash(int key) {
int i = 0;
int number = 1;
int count = 0;
step++;
if(string=='\n') {
number=1;
exp_inc=1;
i++;
count++;
exp_inc+3;
//exp_inc++;
return step;
int i;
int j;
int increment = 1;
int track;
if(hash==hash[j]) {
bingo = 0;
return;
increment++;
bingo=1;
return;
int i;
int number = 1;
return number;
void read(void) {
char entry;
int i;
i=0;
string = entry;
i++;
max_entry = i;
return;
