IonBlade -
Thanks for the info. I agree on the 2005FPW, as I have one on my system in the living room. I think the 2005 is a tad better at color reproduction, and up close, looks a smidge better...although it's probably just the finer pixel pitch. The larger size of the Acer is much nicer for viewing from more of a distance, and is a super bright, fast display. I think the Acer should be a perfect candidate for a wall mount because of both it's larger size, and the added viewing distance from the slightly larger pixel pitch. I fired up the shootout scene on my Heat DVD, and it looked great. I've also been playing some Far Cry and that looks awesome as well.
As for the backlight, bleeding is almost non-existant on mine. I'd say the 2005 has a bit more, but it barely has any itself. I've never seen an LCD with a perfect backlight, but this one is close. I've also noticed the Acer seems to need a lot more "tuning" to get the best image quality more than other LCD's I've used, but it's worth it as you can improve things noticeably with a bit of patience. Let me know if you try those bolts before I do...I'm curious to see if they will work. It seems to be the only way to remove it unless you need to open the whole thing up, but I doubt it. What sort of wall mount are you looking at? I think I'm going to go with a straight flush mount, and just mount it at the proper height/angle for where I will be viewing it from.
Yzzim -
It may be against code in some places, but codes vary widely depending on where you live. It's also possible it was against code but they did it anyway because they were unaware, or just didn't care.
