Is the prob is the ramsinks are too tall? if so I would cut them rather than shim the block. I like the spacers for the cards but I would not want the base of the block to be any thicker than it already is as it seems you would take a performance hit. Just a thought not based on fact or experience.
I won't be water cooling any time soon, too much for me. Just looking at cooling down the 1st GPU a bit it runs at 76C at times, 10C hotter then the 2nd.
