Anyone using Sprint ION?
beer
11,169
Is anyone using Sprint ION?
For $119 a month you can get two phone lines, 8 MEGABIT/1 megabit ADSL, 400 minutes long distance, and unliminted local calling, all over a single ATM fiber piped into your home.
However my DSL now is reliable and any DSL needs to be reliable for me to be able to use it...Sprint PCS isn't exactly the most reliable...
Does anyone have it that can attest to its reliability?
Shockwave
Banned
Sep 16, 2000
9,059
I dont have it, but I work on it. Anyways, I used to. Sprint ION used to be supported by Broadband Service Center (BSC) which is where I work. Dont worry, I'm not gonna try and sell you on it :) The data side is a pretty good deal, but from what I understand, their having a hard time getting the voice side to work correctly. They are using all new equipment (routers switches etc) and the bugs arent all worked out and its the voice side thats suffering. Since I was only responsible for monitoring the switches, I cant say for sure what the status is now. So, the data side is awesome, the voice side is questionable. Something about problems getting all the cool options to work (caller id etc)
