anyone using slot 1 and P3v4x
HouRman
691
If you are using a slot 1 processor on an Asus P3v4x, how did you overclock it and up the voltage.
I only know how to do one or the other. If anybody has any links that would help me to do both It'd be appreciated.
I am running the mobo manual with jumpers and am not able to alter the vcore in the bios. If I run jumperfree mode, I am unable to overclock the cpu where I want it.
AndyHui
Administrator Emeritus<br>Elite Member<br>AT FAQ M
17
You have to run in jumperfree mode, and then set the CPU speed to manual in the BIOS, instead of auto. Remember that you can only change the FSB as most Intel CPUs are clock locked. You shouldn't have any problems changing the voltage either.
