Anyone using simulated sine wave UPS w/ active PFC power supply?
bgc99
472
I'm building a system with a Seasonic Platinum rated power supply and I'm wondering how a UPS with a simulated sine wave output will affect it, if at all?
Thanks,
BGC
OlyAR15
982
242
I bought an APC simulated sine wave ups, did not work reliably with my power supply, was very unstable. Ended up buying a cyberpower pure sine wave ups and relegating the APC unit to my cable modem and router. That way I still have Internet access in the event of a blackout.
Of course, your mileage may vary and your particular power supply may be fine with a simulated sine wave.
bgc99
472
Cyberpower is really the only choice if you want a true sine wave unit that is affordable for home use.
bgc99
472
I assume the APC units have fans, do they run all the time or just when the unit is on battery power? How loud are the fans? I'm trying to build a quiet pc which will be moot if the UPS has a loud fan.
WilliamM2
3,013
892
The SUA750's and 1000's have no fans.
The 2200's we use at work do have a fan, it runs when on battery, or charging. Probably a bit more than you need though, unless you are running servers.
bgc99
472
No servers. I7-4770k, gtx 970, 3 or 4 case fans plus cpu cooler, 1 ssd, 3 hard drives.
I've been looking at the cyberpower pfc true sine wave series, but I'm open to others. I'm wondering if the 1500va unit is worth $40+ more than the 1350va unit in my case.
I turn off my pc when I'm not using it so I would be at it or nearby if a power outage occurs in order to shut down pretty quickly.
Blain
Yes, a 1500AVR Cyberpower (Simulated Sine Wave), and Seasonic SS-520GB active PFC.
I've been running this combo for 2 or 3 years now without any issues.
13,917
Are Supermicro PSUs active PFC? Most of my servers are Supermicro and they're on a square wave UPS. I wish they'd make most UPSes and inverters pure sine though, I really don't get why they don't. It can't be that much more expensive to produce.
This is what a "simulated" sine wave looks like:
Another UPS, switching to inverter:
And back to AC: (that's the same UPS as first pic I think)
