Anyone Using "Pro Tools LE 7"?
Steve
15,945
11
At my last job I set up two users with this program, one with an HP nw8000 and one with an HP workstation - can't remember what it was but I'll look it up at home.
dwell
pics?
I ran it on a Athlon XP-M 2500+ with 1GB just fine. It's not a huge resource hog unless you pile on the third-party plugins.
Steve
15,945
11
What do you want to connect? I've seen it work with Firewire and USB drives.
OVERKILL
2,103
I'm actually going to build a pc for the guy I work for.
I'm trying to find out how it connects to the computer.
He's buying the Pro Tools Le 7 and it includes some kind of audio thing.
The whole kit is like $450.
This audio recording/mixing stuff is all foreign to me.
Any ideas?
Steve
15,945
11
Yep, the users I supported had an MBox and an MBox 2 on their respective systems.
Blazin Trav
Banned
Dec 14, 2004
2,571
Yes...
Using Mac Mini with 512mb ram... about to use a dual core Opteron and 2gb of RAM though...
you don't need a super fast computer, but when it comes to producing music you need a lot of RAM, IMO.
dwell
pics?
Originally posted by: OVERKILL
Thanks Chris.
Also, how exactly does Pro Tools connect to the computer?
You need Digidesign hardware. Probably the Mbox2. You can get the Mbox1 for cheap but don't buy it because support will end for it soon (you won't be able to run new versions of Pro Tools on it.. The Mbox2 is a USB 1.1 device.
I've run Pro Tools on hardware as poor as a 867Mhz G4 Powerbook. It's a pretty efficient application, but as you add more tracks and effects it sucks up more and more resources. The hardware you described can more than run it.
OVERKILL
2,103
Is there any particular sound card thats recommended for Pro Tools Le 7?
Or it isn't a big deal?
